How to Use MathCAD Spreadsheet within Excel
dmicnhimer
1-Newbie
I have a MathCAD spreadsheet that I would like to use in Excel.
What I want it to do, quite simply, is this:
In Excel, I have about 10 inputs. I want to take these inputs, and put them into variables in MathCAD.
The MathCAD sheet will then do its calculation and return 1 variable.
I will take that 1 variable, and put it back into Excel.
How do I get Excel to do this?
1 ACCEPTED SOLUTION
No, 15 is a good answer. Prime (as far as I know) can't interface properly yet. even then the SDK might be expensive...
first point of reference is the help files, its not easy to find but may answer your immediate need:
I have tried various versions but will need to track them down in my archive.
regards
andy
4 REPLIES 4
What version of Mathcad are you using?
Prime or original Mathcad
Right now I'm using 15, but I could convert this spreadsheet to prime fairly easily if need be.
regards
andy
Thanks this helped a lot, and my spreadsheet is now working!
