I am using MATHCAD 15
I want to add additional place holders to write program more than two lines (default)
I am new to MATHCAD I am learning Mathcad using tutorial available in Mathcad help and using PTC community
I need you help and support
at last I found the way to include additional place holder in the add program line
when ever you need additional placeholders press add line button in programming toolbar
or type ]
yes , you are right
thanks for your reply
