How to calculate the age between 2 dates
SOLVED
Participant
Is there any way in Prime 3.0 to calculate the age in years based from 2 dates?
As there are no components (in MC 15 it was possible) in Prime 3.0.
I would need it in a programm routine.
Is it possible with excel component?
thanks
Walter
Tags (2)
1 ACCEPTED SOLUTION
Highlighted
Re: How to calculate the age between 2 dates
If you need to write it into a program then you may need to write several components to do it.
First (as attached) you can convert the string date, assuming a standard format, to day month & year in numeric format.
Second will do the 'subtraction' but it will need additional statements to tidy up over & underflows on days & months and what happens if the years difference is negative.
Might not be an issue for your specific instance but could be a useful addition to a function library.
Regards
Andy
24 REPLIES 24
Highlighted
Hi walter,
See attached, hope it helps
regards
Andy
Highlighted
Andy,
thanks, but how can I use this in a Programm routine?
see attachment and gif pic.
thanks
Walter
Highlighted
The worksheet here: Date Calendar and Time functions.mcd contains a set of functions that are not based on components. I haven't tried coverting them to Prime though.
Highlighted
Thanks Richard, I had this in my MC 15 sheet. But Prime does not support the VB Script component - so I think at thsi time there is no way to run it in Prime 3.0
Best regards
Walter
Highlighted
You may use the function DayNumber() from Richards worksheet. It does not rely on scripted components and should work for Prime, too.
Highlighted
Regards
Andy
Highlighted
Thanks Andy, I could make it!
Highlighted
Hi Walter,
Added a few more lines to the programs - hope it helps
Regards
Andy
Highlighted
Yes, it sheems to be perfect now! Thanks
Highlighted
There are functions at the end of the worksheet that do not use scripted components
Highlighted
Convert to Julian, subtract, then convert back?
Highlighted
fe. BirthDate=1/1/1990
Date2=1/1/2013
age= Date2 - BirthDate = 23.0 years
HOw convert to Julian?
Highlighted
Highlighted
Thanks, littel complicated but ready to enrich my knowledge.
walter
Highlighted
We can do it by Excel help too
Highlighted
Andy already showed the use of an Excel component in the very first answer.
But Walter is in need of a function which can be called from a program.
How would you turn an Excel component into a function?
Highlighted
Sorry, but I did not seen any picture:
Highlighted
Walter needs a function and unfortunately it seems we cannot turn the Excel component into a function (like: DeltaD(d1,d2):=...) as we can do with a solve block.
Highlighted
It would be nice to have something like this attached MC15 sheet that accounts for leap years in Prime 3.
Norm
Highlighted
The leap year handling in this sheet is done outside the scripted component so you can use it as well in Prime.
The only routine which won't work in Prime is SplitDate().
Given that date usually is not given as "15 May 1980" but rather as "15.5.1980" (or "5-15-1980" in other countries) it should be not that difficult to write a Prime only routine to split.
The drawback is of course that without VBScript we have no access to the default date format of the underlying OS.
Highlighted
My attempt in P3 (attached) that matches the MC15 results.
I hope this helps.
Highlighted
Thank you very much, Norm. Now I can also calculate the years behind the comma.
Highlighted
How displayed in the plot two points with dates, such as "01/04/1767" and "05/05/1768"? That is not just displayed the year ("1767", "1768"), but also to consider number of days (just a sum them to a year?).
Highlighted
What about the addition of the fractionofyear to 1767?
see the routine in Norm`s sheet.
