How to create 3-d (vertical) line thru the center of gravity?
How can we more simple create the 1-st and 2-d (horisontal) lines?
See please the Mathcad 15 sheet in attach. Thanks!
Thanks, Fred and Werner!
Both answer are correct! And I cannot put two marks "Correct Answer".
No problem. And as Fred was first ...
