I am attempting to perform the function x(t)=P*y(t) in the attached pdf. The attached prime file is my progress so far. How can I place these functions of y(t) into a vector so I can perform this operation: x(t)=P*y(t) ?
Thank you Fred, this works in Prime 2.0! However, why didn't the c appear in your x(t) symbolic evaulation results while it did show up in mine?
I expect that 15 symbolic engine evaluated c, and Prime didn't.
In mine it doesn't show.
