How to curve fit a function of two variables
Lazar
I have a set of data for a function of two variables f(x1,x2). My function is exponential for x1 with two coefficients that depend on x2:
f(x1,x2)=a*(x1)^b, where a and b are functions of x2.
I found a and b for several values of x2, so I do have equations f(x1) for some fixed x2. I am now trying to find a general equation f(x1,x2).
Is there a way to do curve fitting with two variables-- Mathcad help shows only how to curve fit with one variable?
Every input is appreciated.
StuartBruff
(To:Lazar)
If you have Mathcad 15 or Prime, then you could try the multivariate fitting function multidfit. Otherwise, a solve block will probably handle your problem.
RichardJ
(To:Lazar)
See the attached worksheet
Lazar
(To:RichardJ)
Stuart and Richard,
Thanks for your replies. I'll try to digest your suggestions.
Lazar
