How to format the results
rayakannu
1-Newbie
Can anyone help me to format the result to say 2 decimal places?
1 ACCEPTED SOLUTION
3 REPLIES 3
q.11 is the result of a definite integral and is NOT dependent on x. So it does not make much sense to define it as a function of x. Its a simple numeric variable and you can display it the way you want using normal numeric evaluation with the appropriate formatting options. No need for symbolic evaluation.
