Hey!
I'm wondering if there is a way to get more than one output from a program in Mathcad Prime? In my case it is a for loop and I would like to output both a message and a parameter (1-by-2 vector).
For example:
test = "Error in:" [3,5] ...or something like that.
Where "test" is the function I'm using.
Thanks in advance!
You can nest vectors and matrices. So let the return value of your program be a 2x1 vector where the string is the first and the 1x2 matrix is the second element.
I think I should have been able to see that... thank you for enlightening me
