Security Alert Log4j Security Vulnerability. Click here to know more.
How to isolate "y" values from smoothed function?
MaSu
I am evaluating some measured data with noise. To smooth the data I have used the function "supsmooth". This worked well.
What I need now is to isolate an interval of x values (for example from 100 to 150 with step 0.1) and find y values for each x from the smoothed curve.
How can I get functional notation of the smoothed curve?
Any help is appreciated!
Attached is a ZIP file with data source file and mathcad worksheet with described situation.
MikeArmstrong
(To:MaSu)
Something like the attached?
Just a quick one, always keep origin at 0 as most of the functions posted within this site are based on a ORIGIN value of zero.
Mike
Mike
Hard to tell if the case is smooth or fit !
Worksheet re-attached in M11 format.
Mike
Mike, it is exactly what I've ment. Thank you.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
