How to paste as plain text?
ajimenez
1-Newbie
I am using Mathcad Prime 3.0 and I can't find how to paste inside a text block as plain text from i.e. Word to Mathcad.
I was unable to find anything in this blog or the help documentation. Thanks!
21 REPLIES 21
I generally have to use Notepad as an intermediate for any number of programs which carry the font/size/color hints from one program to another.
In similar cases I've also used AutoIt to read and write the paste buffer to clean up text. It just sits as a double-click item to run and convert: Copy - doubleclick - paste. Not allowed on the current employer computer, so Notepad it is.
RichardJ
(To:ajimenez)
You can't. PTC apparently hasn't figured out the Windows clipboard yet. You also can't copy or paste any graphic except as a bitmap. You can do all of this in Mathcad 15, but I guess PTC hasn't even figured out how to port the code that Mathsoft wrote.
I do not quite understand what's the problem here?
RichardJ
(To:VladimirN)
The problem is that you can't get rid of formatting:
It does not suit?
RichardJ
(To:VladimirN)
Yes, of course you can reformat it afterwards. The point is that Alberto is asking for a paste option that leaves the formatting behind, so that is reformatting is not necessary. Unfortunately, unlike most software (including Mathcad 15) Prime does not offer any paste options.
Ok, now I see what was the question.
Is there a way to make this an official feature request to PTC?
You can bring your idea in "Create Product Idea" area, here: PTC Mathcad Ideas - PTC Community
Why can't I vote and/or comment the following idea?
Improved Mathcad Prime clipboard and graphic import
MJG
18-Opal
18-Opal
(To:ajimenez)
I think you have to be paying maintenance support (is that the right term?) to vote on the product ideas.
24-Ruby V
(To:MJG)
Correct. PTC seems not to be really interested in customer feedback and bug reports. They let you pay for the "privilege" to turn in ideas for product improvements.
MJG
18-Opal
18-Opal
(To:Werner_E)
... and then they promptly ignore the ideas.
VladimirN
24-Ruby II
(To:MJG)
I also do not understand why we do not have feedback on the proposed ideas? Why do not they discuss with the users?
A good question!
Maybe they should implement a chatbot to provide company "feedback" on users ideas. This would round off the placebo "product ideas" .
Someone who will constantly monitor ideas and to debate here in the community.
Richard,
By the way how you cleaning formatting before pasting text from one application to another? I as well as David use Notepad application.
RichardJ
(To:VladimirN)
Notepad is as good as anything, and it's free.
MJG
18-Opal
18-Opal
(To:ajimenez)
Ctl+Space clears the formatting of any selected text (re-formats it to whatever you've set as the format of that text box).
Not a complete solution for what you're requesting, but possibly better than using Notepad as an in-between in most cases.
ajimenez
1-Newbie
(To:MJG)
Thanks Mark Gase, I tried this, and unfortunately it looks like only the color format was removed, nothing else.
MJG
18-Opal
18-Opal
(To:ajimenez)
It appears there are definitely some limitations to my suggestion.  If you copy a single paragraph at a time (no line breaks included in copied text), and paste it into an existing text box/block (empty or including other text), then Ctrl+Space will clear all formatting.  However, if you include any line breaks or try to paste into a blank area of the worksheet, then some formatting remains after Ctrl+Space.
