How to plot perfect star in 3-D ?
SOLVED
Highlighted
Moonstone
   Hello Everyone.
   Many thanks for your time and help in advance.
      Best Regards.
1 ACCEPTED SOLUTION
Re: How to plot perfect star in 3-D ?
3 REPLIES 3
Highlighted
  Many, many thanks for the link, Werner.
Highlighted
Be prepared for heavy fare.
Don't run the exe file - it unpacks the files in the wrong directory.
Rename the file to *.zip and unzip its contents to the handbook directory of your Mathcad installation.
The next time you start Mathcad you can browse the new handbook ("Images") via "Help"-"E-books".
I didn't use the routines to create the 3D-star as you probably have already seen in the file in the other thread.
And if you want it to be even easier you may play around with the numbers (from 1 to 80) here:
