How to plot the star ?
lvl107
20-Turquoise
   Hello Everyone,
   Many thanks for your time and help in advance.
       Best Regards.
            Loi.
1 ACCEPTED SOLUTION
LucMeekes
(To:lvl107)
8 REPLIES 8
More interesting!
I will send my solution tomorrow - with animation!
PS
I learned poetry by heart as a child:
Кремлёвские звёзды
Над нами горят,
Повсюду доходит их свет!
Хорошая Родина есть у ребят,
И лучше той Родины
Нет!
LucMeekes
(To:lvl107)
lvl107
20-Turquoise
(To:LucMeekes)
   Many thanks, Luc. Basic, my question almost was answered. But I still have a small query : the your "Star5" seems not being a "perfect star(5)". Say, compare your "Star7" with following figure that I would wish:
Would it be edited ?
  Best Regards. Loi.
LucMeekes
(To:lvl107)
Play with the arguments to the PlotStar function.
The first defines the number of points. The second defines the size of the points, the third defines the size of the indents, the fourth turns the star.
lvl107
20-Turquoise
(To:LucMeekes)
  Is there a way to describe for general case ?
     Best Regards.
         Loi.
24-Ruby V
(To:lvl107)
I am not sure what you mean with "not perfect".
To duplicate the figure on the right of your picture you can try to replace the argument 1/3 by something larger like 0.6 or 0.7, probably 2/3 will do. The third argument is the distance of the inner points to the centre.
lvl107
20-Turquoise
(To:Werner_E)
  Hi, Werner. I would mean it as the following:
Refer to :   https://www.youtube.com/watch?v=B1Bm1if8zGg     or a similar.
Best Regards.
      Loi.
Learn how to draw a Perfect Star using just a ruler, pencil and compass. This is also the method of dividing the circumference into five equal arcs. With award winning author and illustrator, Shoo Rayner Support this channel and get so much more by joining me on Patreon ➡️ ...
24-Ruby V
(To:lvl107)
You may use either of the following three variants - depending on how exactly you'd like to define a "perfect star". You may also distinguish between odd or even number of vertices.
BTW, why not in 3D?
