How to show less decimals in equation?
JB_9845599
Hi, I want to know how you would show less decimals in an equation and maybe move one part down a line to better fit the A4 format.
LucMeekes
(To:JB_9845599)
You should attach your Prime worksheet file, not only/just a picture.
The symbolic solver works best with symbols and non-magic numbers. Change all items in the equation to symbols, will give you a symbolic answer for RB, expressed in the other symbols. From there you can calculate the result numerically. See here:
(Lacking your worksheet I don't know all the values you put in...)
If you insist on using numerical values with a symbolic solve, change 1.5 to 3/2  and make sure that the values for v, VC, P and P2 are also exact (e.g. v=pi/6, etc). That should ensure that the symbolic solver will produce an exact answer.
Or you should do your solving numerically, using the root() function.
LucMeekes
(To:JB_9845599)
ttokoro
20-Turquoise
(To:JB_9845599)
LucMeekes
(To:ttokoro)
Be VERY careful with this approach. It actually reduces the number of digits that is calculated with, as shown here:
