Security Alert Log4j Security Vulnerability. Click here to know more.
How to solve a linear system symbolically?
rskibba
2-Guest
I have the attached linear system.  I want to solve for X1, X2, and X3 symbolically. three equations three unknowns, however the coefficients are unknown. Is this possible in MathCAD?
1 ACCEPTED SOLUTION
-MFra-
(To:rskibba)
...something is missing...
namely, the vector of known terms B.
9 REPLIES 9
MJG
18-Opal
18-Opal
(To:rskibba)
Here's one way to solve:
However, I'm guessing you wanted a solution other than X1=X2=X3=0
rskibba
2-Guest
(To:MJG)
Thank you for your solution. yes, I am wanting to get X1, X2, xnad X3 in terms of a...f.  It can be solved by hand as a simultaneous equation.  It is tedious.
MJG
18-Opal
18-Opal
(To:rskibba)
Have you solved this one by hand?  If so, can you share?
-MFra-
(To:rskibba)
Your solution just popped up. Yes, this is what I am looking for?  Can B be all zeros?
MJG
18-Opal
18-Opal
(To:rskibba)
Can B be all zeros?
Yes, but then you end up with the solution X1=X2=X3=0
rskibba
2-Guest
(To:MJG)
Agreed
-MFra-
(To:-MFra-)
The worksheet
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
