Hello, Everyone.
The question : How to solve, fully atan(1i*{1 - x^2i}/{1 + x^2i}) = Pi/2 ?
Thanks in advance.
Many thanks, Valery and F.M.
F.M., And Check with MC15 then :
Does this help:
And I base on Werner's suggestion :
Best Regards.
Loi
Good day Loi Le
I hope the solutions provided were helpful - if there was one that helped the most, would you please mark it as correct?
By marking an answer correct moves it to the top of the discussion and make the solution easy for all to find.
Thank you.
Best,
Toby
