How to tell MathCAD something is constant
SOLVED
Newbie
In the highlighted integration, I want to tell MathCAD that the c is constant, but have not been able to figure out how to do so. I've seached some, but no luck.
Tags (2)
Re: How to tell MathCAD something is constant
No need to tell Mathcad so, Mathcad's symbolic treats c as a constant (for MC's numeric c is velocity of light)
I guess you are puzzled as of the huge expression you get in evaluating that integral while you would have expected something like
But while Mathcad treats c as a constant it has to consider all possibilities, c could be -v1, it could be complex, etc.
So Mathcad gives you the results with a lot of if's to cope for every eventuality.
Your function has a vertical asymptote at v=-c, so the bounderies of your definite integral have to be both at the left or both at the right of -c, otherwise the integral would have to be infinity. Obviously c must not be -v1 or -v2 or you would get a divison by zero.
Replace c by a number and see that Mahcad still has some ifs, but less as with an unknown c.
You might try to use assume to get a more meaningful result. Unfortunately "assume" very often does not work as expected. E.g. "assume, -c<v1<v2" should do the job, but doesn't.
EDIT: Interestingly enough "assume, -c < v1" does the job - thats crazy!
In fact "simplify" would not be necessary here, typing it is just a reflex 😉
c:=c
and than the integral
PS
May be this will be interesting for you
http://twt.mpei.ac.ru/TTHB/2/tdceng.html
http://twt.mpei.ac.ru/TTHB/2/Otto-Thermal-Cycle-Mathcad-14.PNG
That is an awesome site. Inspires me to go learn a little Russian.
Thanks!
I try to translate the site into English but...
Can You help me?
Point me please pages of the site and I will translate its.
Some my article in English in this area (themogynamic + Mathcad) You can see here http://twt.mpei.ac.ru/ochkov/work2_eng.htm
