I have a table and I want to use the data in the first column to be displayed as a list box. Once the user select a certain item in the list, then the Vlookup will get a value associated with it. I just don't know how to assign the data from the table to the list box. Is it possible ?
Thank you,
Look in this document for "dynamically filled listboxes": Extra Components.mcd
I think they are what you are looking for.
here is a short script that uses a dynamically filled listbox
Raiko
