How to use document properties inside the document
SOLVED
HolgerSteffen
Newbie
I want to use the document properties (author and title) and the file name of the Document and some custom defined properties to show them at the header of the document
(I want to use an embedded excelsheet to show the properties formated) and at the head line of each page.
At this time, I put a VBA script-object in the document, which reads the data using
Set metadata = worksheet.metadata
Set items = metadata.customitems
For each item in items
If (item.name = "m_discription") Then
Outputs(1).Value = item.value
End If
Next
(I'm not familiar with VBA, I found this code lines in a forum)
It works.
My questions:
-Is there another solution for referencing the meta-data inside the doc and inside the header and footer?
(As in Word, for example?)
-How can I get ,title' and ,author' from the builtin document properties and the filename?
H.Steffen
Re: How to use document properties inside the document
As a minor technical point, it's not VBA, it's VBscript.
No. The only way to do this is via a VBscript.
Here's a function based on a scripted component that will get any metadata item. To get the filename requires another function based on a scripted component.
17 REPLIES 17
Nice worksheet.
Are you planning on putting your scripted components in the FAQ document?
Mike
Yes, I agree that shod be one of the linked documents. A ot of the components that people ask for are already in that document.
End If
Next
It works.
My questions:
H.Steffen
You can't insert a Header (View/Header/footer) and insert file information in them? Version 11 allows this.
I had forgotten you can get the filename and path directly in the header. But in versions 12 and later, no, they did not add the capability of directly accessing the metadata.
Created in version 14, printed to pdf file for discussion.
But you can't get the meta data, such as Company, Author, etc, so easily.
How have you managed to do that Fred?
Mike
Mathcad (v14at least)can create headeers and footers almost like Word. From the View menu select header and footer, and get a window segmented inot three sections with buttons to input file, date, path, images, etc.
Cheers Fred,
I haven't ever tried inserting the file path and name. The only problem is the Mathcad extension at the end of the file name.
An example of a calc number we use is 20000-CAL-DENG-001, but we don't have xmcd on the end.
Mike
Thank you very much.
I will implement that code next time i my form!
If you are looking for scripted components similar to the examples posted here try searching for Extra Components, created by Richard, also Phillip Oakley created a good sheet with many useful functions.
Mike
I have found them see attached, worth filing.
Mike
Thank you, I will do (not now, to much work ...;-)
I will there also look for my 2nd problem:
Putting in the Date of Printing automatically!
The attached is an extract from Richards worksheet, which shows the current date and time.
Mike
Oh another example which has a calendar and also shows the current date as a string.
Mike
Thank you!
