Hello everyone!
I am trying how the MAthcad 15 "Compare Worksheets" command works, it is present in Tools. In this regard, I did not find a mention in the guide. So for proof, I created two very similar and very simple worksheets, but I do not understand how the comparison works. For example the constant b has different values and the number of letters M in the two strings is different but there is no indication about. I enclose a photo of the result.
I thank you in advance for your reply.
Greetings Francesco Mezzanino.
Apparently you have only differences.
Note that differences could also be that the same expression exists, but on a (slightly) different location on the sheet...
Try to make two resembling sheets by first creating one, then create the second by making only small modifications and saving it under a different name. Then do the compare.
