How to use runif(1,1,7) in a program loop?
SOLVED
Newbie
This works:
jx:=10 j:=0..jx k:=0..2 x[j,k:=ceil(rnd(7)) x= displays a 3by10 mateix of integers 1,2,..7
This does not work: x[j,k:=ceil(runif(1,1,7)) x= displays a 3by10 matrix of [1,1] in every cell.
ceil(runif(1,1,7)) works by itself but not as I'm using it (above).
Any suggestions will be appreciated.
Ed
Tags (2)
Re: How to use runif(1,1,7) in a program loop?
Hi Ed,
Rnd() returns a number so everything is OK,
Runif(,,,) returns a vector , so each element is saved as a 1x1 vector within the array.
In this case you can de-vectorise the number as:
ceil(runif(1,1,7)[0)
which seems to work for me
regards
Andy
Hi Ed,
regards
Andy
Made my day! Works perfectly.
Thanks Westerman, hope to return the favor some day.
Ed
