I am getting "Unknown error : bad%_dimension" in monte carlo
SK_9833315
I am getting below error while performing monte carlo. Please find the attachment.
13 REPLIES 13
Mathcad-sheet, please, not picture!
SK_9833315
(To:ValeryOchkov)
Please find the attachment for mathcad file.
LucMeekes
(To:SK_9833315)
You have a double underscore in the definitions for mu_Go1_R2t and mu_Go2_R2b, one too many just before the 'G'. And also in the table Rvals.
SK_9833315
(To:LucMeekes)
removed one underscore. still the same error at Rp_fn.
LucMeekes
(To:SK_9833315)
Units should be OK, since:
and
You have brackets around sigma_r2...?
SK_9833315
(To:LucMeekes)
Removed the brackets. Still the same error.
LucMeekes
(To:SK_9833315)
I have no further clues, sorry. (And I'm limited to Express = montecarlo doesn't work for me.)
SK_9833315
(To:LucMeekes)
Its ok. Thanks.
LucMeekes
(To:SK_9833315)
You should ALWAYS attach the worksheet, or a worksheet, that demonstrates to problem that you have.
From quick observation of the picture, you equation appears to be unit-balanced. But:
If your R values (R0, R1 and R2s) have a sigma of 0, then you probably shouldn't include them in the montecarlo.
However I doubt that you are so sure these resistor values are always exactly the same value.
So another option is to have them vary by at least 1 Ohm or so.
SK_9833315
(To:LucMeekes)
Please find the attachment for the mathcad file.
LucMeekes
(To:SK_9833315)
A single attachment suffices....
ttokoro
20-Turquoise
(To:SK_9833315)
Prime seems not like the units! Delete the units Siemens and it works.
