IE 5 Script Error on Links
Not applicable
While using help, when I click on an underlined word or phrase to jump to the link, I get an error message:
Internet Explorer Script Error
An error has occured in the script on this page.
mk:@MSITStoreJ:\ . . .
Do you want to continue running scripts on this page?
When I click 'Yes' it continues.
How do I clear up the error?
I am using IE 5 ver: 5.00.2314.1003IC on NT 4.0 SP 6 and Mathcad 2k.
Ray
rjoseph@wt.net
2 REPLIES 2
Highlighted
Not applicable
(in response to)
sorry for the incomplete specification:
I have run the Mathcad 2K Pro update. Not all links show this action but I haven't been able to determine which type will error and which won't, but it is about 50-50.
I also noticed that the QuikSheet Examples links at the bottom of the help pages do not work.
Highlighted
Not applicable
(in response to)
Ray,
The first suggestion I would make is to un install and reinstall your Internet Explorer 5.0. There may have been a problem setting up your Java virtual machine during the installation of Internet Explorer. You should go to the control panel and use the "add/remove programs" to un install IE5. You should double click a file called ie5setup.exe on your Mathcad 2000 cd which will install Internet Explorer for you. If you continue having problems please contact our technical support and we will investigate this problem further.
MathSoft Technical Support
support@mathsoft.com
