IF Statements and Matricies
GotsToGo
1-Newbie
MathCAD Prime 3.0
ISSUE 1: I have a square matrix representing collected test data. The data near zero is due to measurement inaccuracy. Thus, I would like to run it through a "filter" to make it zero in a resultant matrix. In Excel, a simple =if(x>1,x,if(x<-1,x,0) is the way to evaluate a given value. I have tried putting IF statements in a resultant matrix to "filter" the values, but Prime 3.0 crashes every time. What is a work around or better way to do this?
ISSUE 2: Now after getting the above to work, I need a clever solution to comparing matricies. I would like to compare the resultant matrix from above to another same size square matrix relative to whether the value is zero, negative or positive. I am specfically looking for a sign change indicating a change in direction fo displacement between what is measured in a test and what is predicted in an FEA simulation. (For the curious: I am comparing the shape of a structure based on 3 points and their X, Y, Z positions.)
Thoughts?
Thanks ahead of time for any help you can provide.
1 ACCEPTED SOLUTION
Instead of using IF statements for #1, you could create a "mask" with Booleans. In the attached example, I look for values where the absolute value is greater than one. I can multiply the original vector with the mask to return only values that are greater than one. You can use the same trick for #2. Use the SIGN function to compare the signs of 'x' and 'y' and see when the two are different.
3 REPLIES 3
That did the trick, thank you much, sir!
David
You're better off posting a worksheet with sample data showing what you want to achieve.
Im not quite sure about your second issue. Which value are you observing (for being +, - or 0)?
You may simple calculate the difference
Looking for sign change you have to deal with 8 cases you have to define what the outcome should be.
+/+ and -/- obviously should yield a 0, as no sign change happened
likewise +/- and -/+ yield -1 resp. +1
but what about 0/+, 0/-, +/0, -/0 ?
E.g. 0/- is not necessarily an indicator of a sign change from plus to minus - that depends on the next value.
See if the attched file helps at least for the first issue.
