Import .CSV / .XLS which is specified by string
SOLVED
Hello Guys
is ist possible to specify the path of an file( which i want to import with the components shown in the attached jpg) by a string.
It would be nice to have the path somewhere in the mathcad-file saved, and the components use that string..
So that I dont have to use the ***** menu of the components!?
I hope you understand by poor english
1 ACCEPTED SOLUTION
Re: Import .CSV / .XLS which is specified by string
I think I have found the problem. I don't think the function likes the .csv at the end of the page name. Try removing it and re-running the component.
Remember once the component has turned red you will have to right click, edit script, and click apply (tick sign)
Mike
15 REPLIES 15
Have a look at the attached worksheet, which uses a scripted component where range and sheet number can be specified within Mathcad.
Mike
Looks fine, but i get an error-message.
Make sure the path is correct. Can you upload both worksheets.
Mike
The Path is correct, but i cant upload the sheets.
Do I need Mathcad 15?
What version of Mathcad and Office do you have.
Have a look at the image below, the component works.
Try right clicking on the component, edit script and click the tick (Apply)
Mike
I use Mathcad 14 and office 2003
The component works with M14 and Excel 2003. It the file path, sheet name or cell range must be incorrect.
Can you take a screen shot of the Mathcad sheet where the file path and range is defined.
Mike
Here you are.
Have you saved both of the files to your hardrive? I have had that problem before.
Make sure the Excel sheet is not open when you run the component.
Mike
