In order to make it easier for Mathcad users to get their work published, Mathcad style templates can be created that satisfy an online journal's style rules. The attached file is one example. It follows the requirements for the International Journal of Chemical Reactor Engineering. The fonts and sizes for each item, such as body text, headings, math symbols, and function names meet that journal's requirements.
To take advantage of this template for possible publication, use the template when you start building your model. Unfortunately, Mathcad does not have a way (to my knowledge) to change all styles in a document after it has been created. When the work is finished, adjust the spacing for proper page breaks. Finally, create a PDF file for the journal.
For this particular journal, the paper title and author are NOT to be included in the article. They are submitted separately on the submission form. See the other requirements on the journal's web page. Always consult the journal requirements before beginning your work to save time making changes later.
This worksheet was created in Mathcad 15.
