Irrational Number and Solving Equation.
SOLVED
Highlighted
Alexandrite
Hello everyone,
I have a question and wish learning. It's about "Irrational Number and Solving Equation".
Thanks in advance.
Loi,
Tags (1)
1 ACCEPTED SOLUTION
Highlighted
Re: Irrational Number and Solving Equation.
sqrt(x)-floor(sqrt(x)) is the non-integer part of sqrt(x). You know that is equal to the right hand side, or to sqrt(7)-2. So you can generate other solutions just be adding an integer to that number.
10 REPLIES 10
Highlighted
Your equation requires that the decimal part of sqrt(x) be equal to the expression on the right hand side. However, since there is nothing to specify what the integer part of sqrt(x) has to be, your equation has an infinite number of possible solutions.
Highlighted
Thanks for your suggestion, Richard.
Following up the suggestion, above. Checking with x=6; x=7; x=8. We have:
So x=7 is the one of the solutions. And the rests of the solutions are the question.
Thanks in advance.
Loi.
Highlighted
Highlighted
I got it. Many, many thanks, Richard. And I have one more related question in "Mathcad Usage". Is there a press button, doing the following:
Thanks in advance.
Loi.
Highlighted
No, sorry. You can go from the one on the right to the one on the left just by evaluating symbolically, but I don't think there is a way to reverse it.
Highlighted
Thanks again, Richard.
Best regards,
Loi.
Highlighted
Just a bit more (all in version 11.2)
Highlighted
I greatly appreciate your help, Steen. I have comprehended that as the following:
Many thanks, Steen.
Loi.
Is that you sending love to Richard????
Mike
http://communities.ptc.com/servlet/JiveServlet/showImage/2-149416-2532/bar_anim.gif
Highlighted
Sorry, Mike. It's a half due to my English and a half due to accidentally hit key.
Thanks for reminding me.
Loi.
