Security Alert Log4j Security Vulnerability. Click here to know more.
Is it possible to perform excel look-up in Mathcad?
dm-3
I would like to know if it is possible to evaluate the equation by substituting the value of corresponding variable in second column of table by giving the input from variable in first column of same table in Mathcad.
Dhinesh
MikeArmstrong
(To:dm-3)
How you did that?
I have included a brief description in the attached worksheet.
Is it possible to add that Mathcad have to throw a message if the value is not in the table?
Yes, by using the 'on error' function, see attached also.
Mike
MikeArmstrong
(To:dm-3)
Is this what your after?
Mike
Mike,
This is the one.
How you did that?
Dhinesh
MikeArmstrong
(To:dm-3)
How you did that?
Mike
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
