Is there a special way to solve non-linear equations without using solve block?
SOLVED
Newbie
Hi all,
I have been struggling to solve a  nonlinear equation, no matter what guess values  I use it seems Mathcad just won't solve it. Please see attached file.
I just need to find the values of P0 at t=0,0.5..5 seconds.
Thanks very much,
Tags (1)
Re: Is there a special way to solve non-linear equations without using solve block?
Sorry, please see screenshot below.
Mike
How about the attached.
Mike
Hi Mike,
Thanks for the effort. Unfortunately our versions of Mathcad are different so I can't try your code. I am sorry for the inconvenience. But I figured it may have been the constraints that I put. So I changed the constraints a little and I got some answers..whether the answers are right is a subject for another day
Mike
That works. Thanks
No problem. Glad you got your answer.
Mike
