Is there a way to edit the program function to otain the output as the below ?
SOLVED
Alexandrite
Hello Everyone.
Is there a way to edit the program function to otain the output as the above ?
Thanks in advance.
Re: Is there a way to edit the program function to otain the output as the below ?
Many, many thanks for your time and help, Werner. Smiley HappySmiley HappySmiley Happy
Best Regards.
