Is there a way to plot a function of (x,y) like ezplot in Matlab?
sfan
1-Newbie
Hi, guys
I want to plot the function:
f(x,y) = x^2 + y^2 +x*y - 3600, bounded with f(x,y) <=0;
Just like the graph shown below:
The figure is plotted with ezplot in Matlab.
function a=elp1(x,y)
     a=x.^2+y.^2-60^2-x.*y;
end
figure(1)
h1=ezplot('elp1',[-90,90,-90,90]);
So far I haven't figured out an alternative in Mathcad that can do this.
Could you help me with some ideas?
Thank you very much!
Best
Shawn
1 ACCEPTED SOLUTION
ValeryOchkov
(To:sfan)
One general method for any f(x, y)
13 REPLIES 13
-MFra-
(To:sfan)
Hi Shawn Fan,
your function is a quadric which can be plotted as follows:
the 2D plot looks like the intersection of the quadric with a plane parallel to the xy plane (z=f(x,y)=a).
For me this is the most simple and basic method ...
Best Regards
FM
ValeryOchkov
(To:sfan)
Lace
Thank you Valery!
This is very helpful!
Could you give me some hint on how you apply the approximate equal?
I use a Greek beta letter to substitute your approximate equal sign since I don't know how to input it in Prime.
When I type f(x,y) and the beta sign, Mathcad will always place a "." in between the two terms, making that beta a variable rather than an operator.
Best
Shawn
ValeryOchkov
(To:sfan)
More correct the approximate equal:
Like this, there is a "." sign automatically inserted when I type Beta
ValeryOchkov
(To:sfan)
And than use infix operator!
Thank you!
Unfortunately I am using Mathcad Prime now and it appears that Prime cancels the infix operator (so sad)
I would use the convergence of say f(x,y) <= 0 to generate a solid(with many points) circle then.
So sad Prime cancels this useful function that looks like a devolve.
Considering Matlab recommends fplot over the old ezplot, while fplot does not come with the same function as ezplot, I feel a little bit better, LOL...
Still, thank you Valery, thank you FM!
ValeryOchkov
(To:sfan)
Prime - three plane 2-d degree curves
24-Ruby V
(To:sfan)
An ingenious method implemented by Viacheslav  N. Mezentsev to do implicit 2D and 3D plots (even for Prime) can be found here:
Re: implicitplot2d()
sfan
1-Newbie
(To:Werner_E)
Thank you so much Werner!
This function is very quick!
I will refer to Mezentsev in my homework.
Thank you!
ViktorKorobov
(To:sfan)
Another method from Viacheslav A.Tarasov. It works in MC 15 but does not work in the Prime (why?).
Viktor
Viktor
Here is a way to simulate it in Prime
Its a pity its not possible to do it the way it works in real Mathcad
Alas - its Prime - what did we expect?
