During using Mathcad, sometime I need some functions that mathcad don't have, such as plot a complicated function or put it in a Geometry Software like Geogbra, then I must translate the mathcad expression manully.
And on the other hand, when I want to calculate some function from other programs in mathcad, I must translate the plain text expression into Mathcad expression.
For example:
It's very troublsome and time-consuming! Is there any method or plugin could translate the expression between Mathcad and the plain text easily?
Remember seeing somewhere a similar transformation from Mathcad. But where?
In Mathcad with Maple symbolic engine (Mathcad 11):
http://twtmas.mpei.ac.ru/mas/worksheets/F_X_Y_Plot.mcd
http://twtmas.mpei.ac.ru/mas/Worksheets/Solve_Symbolic.mcd
and with Polish notation in Mathcad Prime 1 and 2:
and in Mathcad PM http://communities.ptc.com/docs/DOC-2695
It seems that mathcad could insert math region into text region is also have disadvantages.
And the textbox is really a good thing! I hope you can provide the script of the textbox for me, Sir Ochkov.
Do you have Mathcad 11?
I use Mathcad 15, is it can not use the scripts about text to math?
I can do it only in Mathcad 11 by using one Maple function.
So sorry to hear that...
there was a thread that tried to address this (search "Experimentally")
http://communities.ptc.com/message/206094#206094
It will translate some equations from text to math, but some of the useful symbols like square root & integral will need a lot more programming expertise (if possible at all)..
Regards
Andy
