[Issue Report] Exception error because of "The dispatcher process is pending, but .."
SOLVED
jlee-10-11-12
Bedrock
[Issue Report] Exception error because of "The dispatcher process is pending, but the message is still in processing"
Mathcad log Exception data message is "The dispatcher process is pending, but the message is still in processing":
Exception data:
System.Object:
System.InvalidOperationException: 调度程序进程已挂起,但消息仍在处理中。
   在 System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   在 MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   在 MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   在 System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   在 System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
MathCAD Prime 4.0 M010 crashes easily, please improme its Compatibility and reliability, please.Smiley Mad
Tags (2)
Re: [Issue Report] Exception error because of "The dispatcher process is pending, but .."
please report the problem to PTC Support.
Martin Hanák
Martin Hanák
I have sent my issue to PTC's tech support by using "Mathcad Support Center", i choose this option "Mathcad Express,Users who have not yet purchased Mathcad and are using the free Express or 30-day full functionality." I received the feedback phone(From China PTC's tech support center), they said they can't submit this problem to R&D department because i use a Mathcad Express without a valid SCN. China PTC's tech support center R&D department will not accept the issue or bug improvement suggestions unless i use commercial version of Mathcad. I think Brent Edmonds gives us the way to send the issue feedback of Mathcad Express, his vision is Mathcad becomes better and better. I know i am not commercial user, but i just want to let China PTC's tech support center R&D department know and record these problems, maybe they could fix them oneday,i don't need they give me a commercial support. It is not easy to be a man makes positive suggestions to PTC. I will not send issue to China PTC's tech support center, should i try to send to USA?
You may try, but as it looks the sad truth is that PTC seems not to be interested in customer feed back, bug reports or feature suggestions. At least not when it come to Mathcad or Prime.
You have to be under maintenance to turn in a product idea (at least thats as it was in the old Jive Forum) and you have to be under maintenance to turn in a bug report.
Other companies may be happy to receive feature suggestions and especially bug report from whoever as they are interested in improving their software - PTC isn't, as it looks.
Given the way Prime "developed" over the many years since version 1, I have no hope it will ever live up to good old Mathcad 15, let alone improve on it.
PTC seems to have other plans with Prime, so it looks that Prime/Mathcad is a dead end.
Hi Werner,
Thank you for your reply, i can't agree with you more. I have received the reply from PTC USA, they said "regarding your issues. Currently we do not support functionality question for Mathcad trial edition. We only support installation for Mathcad trial edition.If you have functionality questions you can post them at https://community.ptc.com/".
Actually i never expected them to solve my problem, i just want to submit issues to them, and help they improme MathCAD.
Jeff
Please send your issue to PTC's tech support by using "Mathcad Support Center" (you can do it, even if you use Express version of  Mathcad Prime):
http://blogs.ptc.com/2011/09/22/how-to-use-the-brand-new-online-mathcad-support-center/
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
