LeastSquaresFit Problem
Raiko
Hello folks
when using LeastSquaresFit I'm getting an error notification: Unable to cast object of type 'Mcd.NumVal' to type 'Mpl.Run.Function'.
I'm using it for the first time so I'm not certain that the fault isn't mine. Any suggestions where to find the culprit?
Raiko
P.S.
I'm using MC 15 (M020) on a 64 bit Win 7 machine.
1 ACCEPTED SOLUTION
VladimirN
24-Ruby II
(To:Raiko)
Some adjustment for the "f" function:
6 REPLIES 6
VladimirN
24-Ruby II
(To:Raiko)
Hi Raiko,
Any chance to see the worksheet?
Hello Vladimir,
sure here it is. As I said: I#m new to using the solver therefore it might be me doing something wrong. The error message however seems to indicate something's wrong with MC or my machine.
Thanks for your help
Raiko
VladimirN
24-Ruby II
(To:Raiko)
спасибо Владимир !
Raiko
VladimirN
24-Ruby II
(To:Raiko)
You're welcome. Some note about this function:
May be this is a help for you:
