Guess you know that you can't expect a symbolic solution, do you?
Quite a long rope for the time
Thanks, Werner!
One more from Anna Karenina
Here's a more long-winded approach than Werner's. It produces a slightly different result.
Hmm. I tried to post another solution, but had an email saying it was rejected by a moderator. Any idea why? (It contained a jpg image).
I'll try just attaching the (M15) file instead.
My approach was more long-winded than Werner's and produced a slightly different result.
Alan
Are you sure about the formula for the arc length?
Shouldn't it be rather that way:
The difference to my result is now about 1.7*10^-6 % which seems acceptable to me.
Because the Integral uses the derivative of a solve block function, calculation is very slow and a lot of numeric round-offs may sum up.
According your post being rejected by a mod. This really should not happen and is quite strange - especially given the fact, that you sure have built a reputation for yourself as a serious and very valuable forum participant over many years. I also thought that only the postings of new members would be under moderation anyway.
Maybe @Jaime_Lee can shed some light on this.
P.S.: Its nice to see you being around here again!
Thanks Werner, you might be right about the distance, I did it rather quickly, without too much thought - I'll think on it more deeply!
I still look at the site from time to time, but it seems there are more and more PRIME related questions. Since I don't have PRIME I take little interest in them!
Alan
Alan
Yes, Prime sucks and I usually fire it up only to answer questions here in the forum. As long as we have access to real Mathcad, I see no need to actually use Prime, even though Luc had provided a real interesting collection of work-arounds to duplicate a lot of premium functions in Prime Express. You sure know that you can install Prime in parallel with real Mathcad and that you can still use Prime after its evaluation time in its limited "Express" mode.
Hi Werner,
Yes I do know PRIME can be installed alongside M15, and that it becomes the Express version after 30 days or so. However, I'm simply not motivated enough to do that! I'll just stick with M15.
Alan
But it was not an ellipse - if was an oval or 2 lines + 2 arcs.
One frame from the movie
Are you saying that you lied by writing " Then they pulled this rope and drew an ellipse."? 🙂
Sagen = 7 feets
The woman measures, the man counts
Alan
Hi, @AlanStevens Your solution you are trying to provide got caught in the "automatic" SPAM queue (based on the longer string of characters (formula) in your message. The Spam queue is typically reviewed and monitored by moderator team. I am sorry no one got to it fast enough because it definitely wasn't quick enough. Would you be so kind to send the email message you received to community@ptc.com. I should probably make adjustments to the templated information. Also, @Werner_E is correct when he says "This really should not happen and is quite strange - especially given the fact, that you sure have built a reputation for yourself as a serious and very valuable forum participant over many years." We appreciate your contributions and would love for you to continue to share your expertise on the PTC Community!
@ Jaimee_Lee Thanks for the explanation.
I'm afraid I can't send the email as I deleted it immediately (from both my inbox and trash can)!
I see that my mistaken calculation now appears several times!!!
Alan
@AlanStevens No worries! I can dig into the platform templates and try to find it 🙂 Also, if you are uncomfortable with your post (now visible) AND in the attachment on the second post, we can delete it instead of releasing it from "spam jail" for you. It kind of helps the flow of conversation when people don't have to click on the attachment to see it, but just use "Notify Moderator" on the post you would like to suggest the Moderator delete.
Hi @Jaime_Lee
did you read the Anna Karenina novel by Лев Толстой?
Hi @Jaime_Lee
did you read the Anna Karenina novell by Лев Толстой?
Can't say I have! Should we start up some book reviews on the PTCooler?
https://community.ptc.com/t5/PTCooler-OffTopic/bd-p/ThePTCoolerDiscussions
if @Dale_Rosema (who I have nominated to be the President or the King of the Cooler agrees) 😉 I will move this post over and we can start chatting about this book!
You are a happy person - you have not read the Anna Karenina novell yet!
Just looked it up on Wikipedia. 800 pages! Sounds like a pretty involved plot!
https://en.wikipedia.org/wiki/Anna_Karenina
I think for now if we were to start any "Book Review" conversations on the PTCooler maybe we should stick with Engineering related topics 🙂
I vave a lot of same problems here
2⁵ Problems for STEM Education - 1st Edition - Valery Ochkov - Rout (routledge.com)
Examples
in Russian
1 верста
2 версты (two of versta)
3 версты
4 версты
5 верст
6 верст
7 верст
8 верст
9 верст
21 верста
etc
Leo Tolstoy. One picture by Valery
(no solution without animation!)
Thought I'd have another go (and also see if I can upload images yet!):
Alan
Solution of new problem - not S=1верста, but Gold Ellipe!
Red - a gold ellipse, Blue S=1 versta
