Linear Interpolation from one column of a matrix
SOLVED
Eng_ReyD_497
I have X & Y defined as two matrix variables, which I can do a linear interpolation between them...
How can I perform the same interpolation if I have X & Y in a combined matrix, ?
I am attaching the Mathcad file
You can use the 'column operator' to select/copy a column from a matrix, keyboard shortcut [Ctrl-Shft-C].
See attached.
See attached.
Eng_ReyD_497
(To:LucMeekes)
Thanks @LucMeekes
I wanted to perform interpolation within the matrix, not just splitting it into columns. However, I used your technique and built the next step of the actual interpolation and it works... Thanks a lot.
I just wanted to show you what I did with the interpolation itself in light of your help, which I assume is what you meant; unless you have a different approach just to learn from it ...
Thanks and all the best!
You did it correctly. If you don't want to break up the matrix, this:
is the way to do what you want.
Note that I used ORIGIN in my example, and you've used it also. It is the safest way to point to the first element (or column or row) of an array.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
