Linear Interpolation from one column of a matrix
Eng_ReyD_497
8-Gravel
I have X & Y defined as two matrix variables, which I can do a linear interpolation between them...
How can I perform the same interpolation if I have X & Y in a combined matrix, ?
I am attaching the Mathcad file
LucMeekes
(To:Eng_ReyD_497)
You can use the 'column operator' to select/copy a column from a matrix, keyboard shortcut [Ctrl-Shft-C].
See attached.
LucMeekes
(To:Eng_ReyD_497)
See attached.
Thanks @LucMeekes
I wanted to perform interpolation within the matrix, not just splitting it into columns. However, I used your technique and built the next step of the actual interpolation and it works... Thanks a lot.
I just wanted to show you what I did with the interpolation itself in light of your help, which I assume is what you meant; unless you have a different approach just to learn from it ...
Thanks and all the best!
LucMeekes
(To:Eng_ReyD_497)
You did it correctly. If you don't want to break up the matrix, this:
is the way to do what you want.
Note that I used ORIGIN in my example, and you've used it also. It is the safest way to point to the first element (or column or row) of an array.
