Liquid Flow Through Pumps in Parallel
TudorMarin
Newbie
Description:
Two pumps in parallel pump water from a reservoir according to the schematic below.  Experimental data describing the head/flowrate relationship for each pump is available.  This worksheet will calculate the flowrate at the exit piping.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
