Log axis crossing
SOLVED
Newbie
Log axis crossing
I have a log-log plot. The y-axis range is 0.01 to 1.0. The problem is that the x-axis is labeled at the TOP of the y-axis.
Is there a way (as there is in EXCEL) to change where the x-axis labels are placed (i.e. - I want the labels to be at the lowest y value (on log scale) of 0.01)?
Tags (3)
Re: Log axis crossing
Double-click on the plot, select the "X-Y Axes" tab on the resulting dialog (should be the default tab anyway), then change the "Axis Style" at the bottom of the tab to "Boxed".
Stuart
12 REPLIES 12
Which version of Mathcad are you using and could you post an example worksheet.
version is Mathcad 15.0
I don't know how to add the example, but this is the plot.
Click u'se advanced editor' and then you will have the option to attach files.
thank you...
How about the attached?
Stuart
I don't know why, but the choices for axis are boxed, crossed, and none.
On my version 15, I get your picture with crossed; with boxed the x axis is at the bottom.
Removing the log scale from the Y-axis will also do the job.
