Low resolution Excel component
Erica
1-Newbie
I want to create a table that has labels across the top row and labels down the left column. It seems that a regular Mathcad table will not allow this because it thinks my labels in the left column are undefined variables. I would like to use an Exel component for the table, but the table prints kind of fuzzy. Is there a way to get a higher resolution Excel component? Or just a better way in general to enter such a table? Thanks
1 ACCEPTED SOLUTION
wayne
3-Visitor
(To:Erica)
Without using Excel, you can do simethin like the attached
7 REPLIES 7
wayne
3-Visitor
(To:Erica)
Erica
1-Newbie
(To:wayne)
Thanks for your document Wayne. How did you display it as a table with borders? Is that still possible with Prime 2.0?
wayne
3-Visitor
(To:Erica)
I don't have Prime 2 right no, but in M15
select the matrix, the Format>Result>Display Options>Matrix display styl
to get rid of (or show) the automaitc column and row headings, right click on the talbe and slelct properties from the drop down menu.
Erica
1-Newbie
(To:wayne)
Great. Thanks a lot.
VladimirN
24-Ruby II
(To:Erica)
Erica Rendon wrote:
...as a table with borders? Is that still possible with Prime 2.0?
No. In Mathcad Prime 2.0 results can not be displayed in tabular form. The result is organized as a matrix. Converted document for Prime 2.0 attached to the message.
Thanks Vladimir.
VladimirN
24-Ruby II
(To:Erica)
You're welcome.
