M15, Hyperlink to a web page URL: how to set the browser that will be launched
ClaudioPedrazzi
11-Garnet
Hi everyone,
it seems to me a pretty dummy question, but I am not finding the setting I am looking for.
I use occasionally the "insert Hyperlink" dialog, to link URLs of data sources or other informations in my worksheets.
Now I realized (don't know since when) that the browser launched when I double click is Google Chrome (not my default browser, that would be IE). Not a big problem, but is there a setting where I could define which browser to use?
This happens even if IE is already running in the background.
Thanks a lot
Best regards
Claudio
7 REPLIES 7
As far as I know there is no way to set the desired browser from within Mathcad. For me the systemwide default browser is opened.
Could it be that on your system Chrome was set as default browser without you noticing it?
Hi Werner!
Thanks for your answer.
"Could it be that on your system Chrome was set as default browser without you noticing it?"
not really, because the first time it happened, Chrome was asking "Chrome is not your default browser, do you wish to change it" and I clicked no, and dont't ask anymore (so I don't get the message now). Also if I click into a link from Outlook, for example the E-Mail from this forum, I get IE opened.
And finally, in the "Settings" of Chrome (opened via Mathcad ), it says
(for non german speakers: Google Chrome is at the moment NOT your standard browser).
Strange effect. I tried on my system (which still is XP) and changed default browser a few times to FF, Chrome and IE and everytime Mathcad would open the correct one (the defauklt browser).
Not that it is sooo important, but you made me courious and theese are the settings by me (Windows 7). And the effects. And the test file.
The "v" sign on "Chrome-HTML"-Document cannot be deleted.
The test file contains just one text and a link to this discussion. Just to verify that it is not a site-related problem (because until now I always tested the same hyperlink, from the Sandvik online Catalog). It happens also with the ptc.com site.
Is this the dialog you get when you chose control panel (Systemsteuerung) / Programs (Software) and then "Default Programs" and "Set your default programs"? I am not sure and at the moment have not access to a Win7 machine. If yes then it looks like Windows (not Mathcad, I guess) is ignoring those settings which is strange enough. BTW, your file works as espected for me - that means that FF (my default) fires up.
Yep.
Programme -> Standardprogramme -> Standardprogramme festlegen ->
should be exactly what you mean. Then you get a list of programs like this oneUnbenannt4.JPG
and if one selects the option "standards for this program define" (red), then one has the lists of file-types that I posted above. I did this just for the sake of checking, but I am sure that IE is the default browser, since it opens from Outlook, from inside a PDF, and so on. I think I have found a bug.
By the way thanks for opening my test file, this confirms me that I am doing all correctly, it is the system that fails. Have a nice weekend!
Claudio
I see much the same thing you do (in English, of course!), except that .shtml is associated with Firefox, my default browser, and I do not see the checkboxes on the left.
