MATHCAD FOR ENGINEERS: OPTIMIZATION OF RIGID BODY DYNAMICS EXAMPLE PROBLEM
kpisacic
Newbie
In this paper, an example problem was used to demonstrate the application of Mathcad in solving the tasks of
the dynamics of rigid bodies. The task was to determine angular acceleration for a given moment and the moment value
at minimum acceleration, which makes this problem an optimization problem. Classical analytical solution of the
problem is obtained using the D'Alembert principle. Mathcad code is given by which the solution is obtained.
Functional dependence of angular acceleration to frictional moment is determined and final solution is calculated by
the minimization function. Comparison of optimization solutions to classical solution confirmed the effectiveness of this
method of problem solving. For this procedure Mathcad symbolic functions were used.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
