Masonry design BS5628
Farazstani
Visitor
Hi guys, in BS5628 there is a 'small area factor', this equates to "0.7+1.5A"
A=area
I keep getting the error "these units are not compatible". I know its because 0.7 doesnt have any units, but the factor itself doesnt have units.
Is there a way around this?
6 REPLIES 6
Re: Masonry design BS5628
If its a "factor! I would expect it to be used in a product, not a sum.
BTW, are you sure you are posting in the proper area of this forum?
Wernerexinger, sorry I'm new to this. Where should I direct this query?
The small area factor is "0.7+1.5A"
It is then used in a product further down the design process
The forum software changed recently (not to the better) and is new to all of us.
In fact I have no idea which software you are talking about so I can't guide where you should post.
Click "Browse" in the top line and hopefully you will an entry for the software you need help for.
Good luck!
@Jaime_Lee Please move this discussion in Mathcad forum, here: https://community.ptc.com/t5/PTC-Mathcad-Questions/bd-p/PTCMathcad
Quickly searching online, I found this:
Please verify this is what you are asking about.
If so, then A should be divided by m^2 to get a unitless factor.
Edit:
Here is one possible implementation.
Yes thats it.
Thank u very much, simple solutions always work out best!
