Matchcad 15 conversion - Invalid Host
SOLVED
Highlighted
Re: Matchcad 15 conversion - Invalid Host
@LucMeekes wrote:
I suppose you meant "running a gauntlet" instead of just "a gauntlet"...
Correct!
In German: Spießrutenlauf
Thanks for your time everyone, I've tested it will the standalone converter and same issue. Will now approach support as suggested. Will leave this unsolved and come back with the resolution once resolved.
Ok so the big reveal....... the issue was caused by an old file. So it turns out that the file(s) we are trying to convert are really old, created in 2001. Not sure why it produced that error but that's what it did.
We opened the file in Mathcad 15, re-saved and then was able to convert.
Once again, thanks all for everyone's input to begin with.
It's still PTC sofware...
But what a swift response of PTC support!
And so great that your problem is solved!
Now... do the sheets work in Prime the same as they worked in (real) Mathcad without modification?
Yep, tested with a file that had calculations and graphs.
