Math Formating complex number polar with degrees
Newbie
Hello people,
I use Mathcad for college, and its a very usefull program.
About a week ago Tab "Math Formatting" is normal, but don't update sheet, see example:
I Start a new, then Tab Math Formatting, and choose like in piccture.
When i start make calculations, it never respect new Formatting.
I already have "repair", "uninstall" and "install" again.
One use is complex numbers, i choos to show in polar degrees, and it shows in rectangular, why?
Anyone has the same problem and was able to fix it?
Luis Lourenço,
Portugal
4 REPLIES 4
Re: Math Formating complex number polar with degrees
You're using symbolic evaluation. Does it do the same for numerical evaluations ( = instead of -->)?
If the cursor is in an evaluation when you select the formatting it affects only that evaluation. To change the default formatting for the worksheet click on a blank area of the sheet, and then change it.
Highlighted
Good catch! It works for numeric evaluations, not for symbolic evaluations. If you click on a symbolic evaluation you do not even have the option of changing the formatting of the result.
Hey Fred Kohlhepp, your answer was gold
Thank you very much. I really appreciate that.
Luis L.
