Math formula formatting messed up (multiply operator and parens affected)
ptc-3168830
1-Newbie
My installation of MathCAD 14 is messed up.
It used to work correctly, but now the multiplication symbol has turned into an empty square. I can't figure out how to restore it to normal. I tried uninstalling and reinstalling MathCAD but it didn't change the behavior.
Also, a left-paren and right parent look normal when on just one line. But if I put parens around a fraction e.g. (3/4) I see a a bunch of empty boxes instead of the parentheses.
1 ACCEPTED SOLUTION
Probably the symbol font is corrupted. Delete it from the Windows font folder and reinstall it. Double clicking on a good symbol.ttf should do the job.
Another possible candidate is the Unimath font which can be found on your Mathcad installation CD.
3 REPLIES 3
Thanks. That was the problem.
RichardJ
(To:ptc-3168830)
As Werner says, the symbol font is corrupted. Delete symbol.ttf from the fonts folder and install a new copy (attached). Note that the font needs to be installed, simply copying the new file to the fonts folder is not enough.
