MathCAD File Corrputed
SOLVED
Highlighted
Hello everyone,
Does anyknow if it is possible to rectify corruption inside of a MathCAD Prime 2.0 file?
I have attached the log file that was generated when I attempt to open the file.
1 ACCEPTED SOLUTION
Re: MathCAD File Corrputed
Hello Ashley,
Looks like a corruption in the zip format, so well worth logging a report with the tech support guys - hopefully helps them to make prime 3 a little more robust.
Regards
Andy
7 REPLIES 7
Can you provide this Prime 2.0 worksheet?
Yes I can
What is contained in your file (what type of calculations, plots, inserted pictures)? I also can not open this file in Mathcad Prime 2.0.
Some fairly basic Trigonmetry equations but they took a while to figure out how to do (they are in relarion to the Australian Stairs and Platforms Standard).
Try to contact with PTC tech support by using "Mathcad Support Center": http://www.ptc.com/support/mathcad_supportCenter.htm
Hello Ashley,
Regards
Andy
Hello Andy,
Something a littl bit random happened. I opened the attachment that you psted and the file opens.....
But I will send this onto the tech support to help them with Prime 3
