Mathcad Plot with an if-statement?
SOLVED
Newbie
First time posting on these forums, been reading around for a couple of years though.
I would like to create a plot of 4 functions (let's say it's different pressures depending on a variable, h). I've done this in the appended example.
However, I would now like to plot only 2 of the functions if a variable, say "condition", is =1.
How can I do this?
I have tried adding an "if" statement on the y-axis of the plot itself, like this:
f.1(h) if condition=1
, but I get a critical error when doing that, and the plot goes blank.
I'm using MathCad 15.
Any suggestions are appreciated,
Thank you,
Hampus
Tags (2)
Re: Mathcad Plot with an if-statement?
NaN (non a number) is very useful when you want something to not show on a plot. It works for either entire plots, or individual points.
8 REPLIES 8
Richard,
Thank you, that worked perfectly!
Nice trick that Richard
Yes!
Wish 3D plots could handle NaN's as well! (its a bit better in Prime but not sufficently)
Depeding on your needs it might be convenient to use a wrapper function based on Richards solution.
See attached.
I wish that could be said about other capabilities of 3D plots in Prime
I must have missed something - Plots in Prime have capabilities?
Nifty! That's a keeper, thanks
