Mathcad Prime 3.0 installation failure on Windows 10
MC_9627349
The installation on Windows 10 failed. Is there any chance to be installed on this OS ?
Looks like you are not the first user experiencing this problem.
The last post with this problem I could find was this one: https://community.ptc.com/t5/PTC-Mathcad/install-mathcad-prime/m-p/566829#M181889
Unfortunately the only advice we could give is to contact PTC support.
LucMeekes
(To:MC_9627349)
Any version of Prime should install with no problem on Windows-10.
Prime 3 is no exception.
What exactly went wrong?
MC_9627349
(To:LucMeekes)
Hi Luc
Thank you for your fast response.
The issue with my installation is that when I get to application selection there is no application to select (photo attached) and the folder created on my disk is empty.
Thank you again.
Mike
MC_9627349
(To:Werner_E)
Thank you for your advice and hints. Problem solved.
I followed your link and got a hint from Peterle how he solved his problem. Furthermore, using https://www.ptc.com/appserver/lm/mathcad/download/index.jsp I was able to download the release Prime 3.0 folder for my  Mathcad Prime 3.0 Student Edition and using my license the installation went smoothly.
