Mathcad Prime 4.0 ( Need the the solution for this problem ASAP )
Level 7
I need the solution for the problem shown in the attached photo asap.
 Thanks in advance.
Re: Mathcad Prime 4.0 ( Need the the solution for this problem ASAP )
Tp/sqrt(Hs) has units of s/m^1/2 whereas 5.75 is dimensionless. You can not subtract apples from a dimensionless number. 5.75 must be in apples too.
We sorted this already,
Highlighted
Whats the point in asking the very same question twice??
Its already answered here -> https://community.ptc.com/t5/PTC-Mathcad/Mathcad-Prime-4-0-Need-the-the-solution-for-this-problem-AS...
If there still is something unclear to you then ask there.
Based on the time stamps I think this is probably a glitch in the forum's wonderful software.
It's not a glitch. The op posted the item twice with different tags.
