Mathcad Prime 6 - Math Formatting - CRASHES
Regular Member
When using Math Formatting on a multiple selection it completely crashes the program.
On top of that, it shows this message about succesfully saving the file and when this saved/recovery file is open, it fails to open it saying "wrong format".
It looks to me like 2 bugs tightly linked together.
Anybody else experiencing the same problem?
5 REPLIES 5
Highlighted
Re: Mathcad Prime 6 - Math Formatting - CRASHES
if you can reproduce the problem, please report it to PTC Support.
Martin Hanák
Try to contact with PTC tech support by using "Mathcad Support Center": http://www.ptc.com/support/mathcad_supportCenter.htm
Thanks. Already done: 15150354
I use math formatting extensively in and out of text regions.
I don’t have any problems.
Prime has been rock solid for me since 3.1.
Anyway, can you explain more or share a screen shot ?
Congratulations about your experience with Mathcad Prime.
For me it has been of great help and really helpful.
It has been reported to PTC support team and they are working on it.
I trust they will solve it, it is not the first time I had a problem and they solved it.
When a solution is found I will update this discussion.
